it got warm once this last weekend but had it on loud for a long time trying to get gains right to hopfully fix problem but then tonight on the way home from work it turned off f and when i got home i checked to see if it was warm and it wasn't at all it was still cold
check your fusing. i had that same problem with mine tonight. all of my wires and ground are working perfectly, so i checked my fuse. it hadnt blown yet, but it had begun warping from the power it was getting and it was sending my amp into protect. im only running 300rms right now at a 4ohm load.
Edited by J00bles
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
check all your fuses look to see if there is any melting or burn marks
on them and if it looks to be in any kind of damage replace it. Also if
its just melting and changing the coppers colors from heat most likely
your running to big of a fuse.
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
just checked all the fuses they all look like new
idk how it could be the ohm load because iv had it for like 4 or 5 months and everyting worked goodd till now
Do you understand ohm laws and what an amp stable ohm load means?
I'd still recommend double checking your ohm loads.
Single or dual voice coil subs?
What ohm for each coil?
What wiring between each coil?
What wiring between each sub to amp?
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
another thing it could be is lack of power?
check your 12v connection and if you have a dmm
check how much power your amp is seeing i know its only 400w
but you could have a bad battery connection.
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
that could be it the insulation could be rubbed off causing the
wires to rub on the door and power is being grounded off there
or something like that i would check that asap
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
