Kenwood Kac-9104d Vs Hifonics Bxi1206d
troy
• 1800 Watts Maximum Output Power with 30% Smaller Chassis Size
• 500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
• 1-ohm stable (output regulated to 900 Watts)
• Variable low-pass filter (50-200 Hz at -24 dB per octave)
• Subsonic filter (15/25 Hz, 18 dB/octave)
• Class D design
• Fuse rating: 30A x 2
Super D-Class Monoblock Amplifier
RMS Power Ratings:
1 ohm: 1200 watts x 1 channel
2 ohms: 900 watts x 1 channel
4 ohms: 450 watts x 1 channel
BXi AccuCross™ active electronic cross-over permits full adjustment of:
Bass EQ, Subsonic Filter, Low-Pass & Phase Shift features
Highly Efficient Super D-Class Amplifier Circuitry With Oversized MOSFET Output
±18dB Variable Bass Equalization @ 45Hz
180° Variable Phase Control (15 to 35Hz)
80 amp fuse rating
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
any specific reason why?
because even though the hifonics amp is overrated, the kenwood is as well. the kenwood is "rated" at 900 rms, but is overrated just like the hifonics amps.....i think that you will like the hifonics better, ive had some of the brutus amps as well as the crunch pzi amps that are very similar to them and they were very good amps for the money. everyone that ive ever talked to thats had kewood amps say they have had problems with them.
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
I have that exact Kenwood amp, its a spare incase the 4kw goes down. It puts out a whopping 648 Watts rms at 1ohm on the bench!! haha. It was cheap though, $30 from best buy 2ndtrun place on ebay. Hifonics all the way in this case unless you can score a deal!!!
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
the kenwood is cea compliant which means it does rated. but i do think i am going with the hifonics.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
i know people have told me that they do around 900 if not over which is plenty considering i only need 800 out of it.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
a BAD ASS amp i had one before with two tvelves and it was SLAPPING.my friend had a kenwood nad it wasnt that good.
  • Who's Online   0 Members, 0 Anonymous, 1006 Guests (See full list)
