depending on how much hardener you use, it could dry fast, or it could take a lil longer. and depends how warm it is. just go back every once in a while and poke at it
is there a certain amount i should use? or does it say it on the can?
i did 10 drops of hardner for every ounce of resin while it was 80 degrees outside today so if its a little cooler you could actually mix a lil hotter if u want and put a few more drops per ounce just dont go overboard cuz the resin will get to hot and crack and if u mix it hot give it at least thirty minutes to dry then check it and if its still not dry just check it every ten minutes or so its kind of a tedious project but well worth it if u cant do 45's with wood
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
ok cool! any preferred brands or where to get the resin?
Honestly i went to lowes and picked up the elmers resin and hardner kit it was like 15 bucks for 32oz of resin and a little tube of hardener worked perfect for me
it was with all the wood glue and what not.
Edited by Moore941
1 Dc lvl5 18
shootin for 145+ :)
