Just mix it according to the instructions on the resin. Don't mix in too much hardener though because it will cure before you are ready. You can get it so hot that it will actually crack.
Just prop your box up on an angle, then pour in the resin. Gravity will hold the resin flat in the corner. Once done with one edge, go on to the next.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
Thanks!! :friends:
after that i dont smooth it out or anything???
i have i would put a little less hardner in and let it take its time not a bunch less just a few cc less or drops whichever your using
how long should i let it dry???
i just did this in my box i did a lay of fiberglass over it also just for extra strength, its not neccesary if u look in my build ull see its simple but it take 30 minutes to an hour for each corner just so u know
mine arent really 45's just a nice angle to keep the air flowing and add strength
hope that helps
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
depending on how much hardener you use, it could dry fast, or it could take a lil longer. and depends how warm it is. just go back every once in a while and poke at it
hope that helps
thanks. im gonna start building the box soon so hopefully it goes well
