Bass Boost And Why Its So Bad?
bennett15
gain is set correct with dmm but it was the bass boost i had to have quite high
too get the FI to sound how it should
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
not necessarily, if the preout for the sub has left and right u might need both to get full voltage
but in this case it works like that
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
50hz 0db with bass boost set before gain was. But recently ive tried to reset my gain
with dmm and i do everything like it says to unhook subs put dmm's leads into speaker channels on amp and set dmm on ACV 200m
and then play the 50z tone and start tuning gain up and my dmm reads zero all the time?
Any reason why its doing this?
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
this happens sometimes for me...
first, use -3 or -6... u will be turnin the gain up a bit more, but its overlaps.. no music is recorded at that high of a level... so reset with -3 or -6..... hell RF recommends -5 or -10... i say thats a bit of a stretch imo...
and if urs is autoranging... select ac and the range by urself... and tighten the screws down an test the screw heads... sometimes that cures it
if ur not getting a reading, ur not doing it right... and u need to keep doing it til u get the right ac voltage without bass boost, its not needed at all on that amp
Amp is Hifonics Brutus bxi1608D if that makes any difference
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
so could you explain why i dont get a reading and i went and picked up\
a rca y splitter and hooked ut up and boost doesnt even have to be past 6db to be as loud as
before.
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
i dont know why u didnt get a reading, but keep tryin, u will... and dont be satisfied til you do
im not gonna guess cause im not sure... but just use the ysplitter... reset gains with -3 or -6db 50hz sine wave... or i can let u have my -5db sine wave which seems perfect... or u can create ur own with audacity
edit* for some reason ur amp might be getting double the voltage in the rcas now, so u need less gain and less boost
but thats a guess with little explanation, lol
  • Who's Online   1 Member, 0 Anonymous, 1698 Guests (See full list)
