enemyofsilence Posted April 3, 2009 Report Posted April 3, 2009 so i have been planning to put a dc lvl 4 18 into a expedition. I went to re's website to see their box calculator. This is a rough sketch of what i came up with. ln dc's website, the suggested ported area for the box is 5.75 cubes. What do you guys think? will it hit lows and still sound good doing it? any comments or suggestions are appreciated. EDIT: this is going to be a daily driver set up and powered by a rf p1000bd. Team Bass-Hz
enemyofsilence Posted April 4, 2009 Author Report Posted April 4, 2009 BUMP for advice? :hairtrick: Team Bass-Hz
thehoe92 Posted April 4, 2009 Report Posted April 4, 2009 29-30 hz will hit the lows for sure. good luck with the build man Wouldnt be thehoe92 without teh purple
enemyofsilence Posted April 4, 2009 Author Report Posted April 4, 2009 this is probably a noob question but how much square port are should i have? and what is square port volume displacement? i have been trying to figure it out but i would like some clarification. thanks. Team Bass-Hz
dynodan9 Posted April 5, 2009 Report Posted April 5, 2009 I have heard that a safe number is 12 sq inches of port for every cubic foot the box is. so id say for a 5.75 cube box you would need about 66 square inches of port area.
Neo_frog Posted April 5, 2009 Report Posted April 5, 2009 I have heard that a safe number is 12 sq inches of port for every cubic foot the box is. so id say for a 5.75 cube box you would need about 66 square inches of port area. You could even go a bit bigger if you wanted (port area). Just remember to compensate for port displacement when you're building the box so you don't end up losing net air space and raising the tuning involuntarily. Good luck man! Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Joker Posted April 5, 2009 Report Posted April 5, 2009 Try this in the RE calculator ~ 30 20 30 30 5 0 2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune 1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
Boon Posted April 5, 2009 Report Posted April 5, 2009 That port is way too big. You want around 80 square inches IMO. 10.x volts fo' life!
