whats up everyone, ok igot a 99 s10 that is already bagged, but it is really really slow not sure of the exact setup guy said i need a bigger tank, just wanna get some ideas or thoughts of what it is, i had a bagged truck b4 and it was quick, this truck u hit the switches up and it doesnt move hardly u have to hard the switch in for a good while any ideas thanks
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
need bigger valves maybe? i been learnin about air ride a lil, but maybe a bigger tank too so ya have more air ready when ya need it
You need more of one of three things...or all three..or a combination of.lol
1. higher pressure in your air tank
2. larger valves
or 3. larger line.
All a bigger tank is going to do is give you more playtime and increase your fill times....neither of which you stated you wanted...lol
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
use a nitrogen tank along with the normal airide setup. if i remember right steve did this too. use it when it need s to be done faster than waiting in the compressor/s
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
ah cool. i learned something too :D i figured it was a matter of gettin more air to the bags with the bigger valves. i see with the bigger tank for sure. im still workin on gettin the bonni rimmed up lol
...and ive read th nitrogen tanks are just for fast spurts but wouldnt ya still need bigger valves too?
2. larger valves
or 3. larger line.
thats what i thought about the bigger tank lol, how do u get higher pressure in ur tank??
and is there any way u make adjustments to the valves??
sorry im a newb to airride my last truck was really fast
thanks for all the help guys thats y i love this site hahahaha
new toy
bagged
22s
REFS
technically yes bigger valves would still be needed. but that is waht you would want is a fast spurt
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Higher pressure can be achieved by adding a higher value pressure switch so that it turns off your compressors at a higher pressure....like 200 psi vs 160psi
You can also add a nitrogen tank with regulator and set the regulator to fill the tank to a higher pressure.....but they are not cheap. The only way to get more flow through your valves would be to upgrade them to a larger size....unless it's the size of your fittings and line that is restricting the flow of air.
yea i have no idea i thought there were adjustments on the valves, ill get pics soon and post them and than somoene prob will no exactly what to do lol hahahaha thanks
new toy
bagged
22s
REFS
  • Who's Online   0 Members, 0 Anonymous, 1485 Guests (See full list)
