I got an okay system with Kicker speakers and a Bazooka dual 10's. Worked nice for about 6 months before I started getting a bad case of alternator noise and then the system started cracking up at mid volumes. I thought I blown the speakers at the same time.
After installing two PAC filters, my speakers were crisp and playing ear bleeding volumes again but I noticed the subs sounded really different. It sounded like it could only hit ~65% of its normal power and the low lows (if that makes sense) weren't there anymore. What's going on?
In terms of details, I'm a noob at wiring so I just installed the filters between the amps and subs instead of behind the headunit. Secondly, I grounded the filters to each other's ground wires which seemed to actually work.
Any help would be great. The treble and mids are killing me even wit them turned down.
Wow, what? You wired an RCA filter between your amp and sub?
What a fucking disaster. Pull it out and do it properly.
Edited by Boon
10.x volts fo' life!
just ground your rca's no need for the filters.
I have no idea how to get to the back of my headunit (I tried to stick my head in behind the thing where the pedals are but can't see anything) nor do I know how to pull it out. I thought I could just install the PACs right before the amps in the trunk but the person that installed my setup did a rather confusing installation to me because my speakers' amp is out in the open in the trunk (with only enough connections for 1 PAC) while my subs' amp is built into the back of the box which is behind my rear seats but it has 4 plugs (2 Red/2 Whites) for both PACs and that's where they currently are right now.
Get rid of the filters first. And second I believe you have your amps mixed up possibly??? Maybe a bad installer... Sub amps have one pair of RCA inputs while 4 Channel amps have 2 pairs of RCA inputs.
EDIT: IF the installer did mess up that bad they deserve to be fired.
Edited by bumonskateboard6
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
If I remember correctly from some years ago, I think the installer mentioned something about just wiring the 4 channel amp like a 2 channel, which may be the reason why there's only two RCA cables running to it.
As for the sub's amp, not sure why but there is, in fact, 2 pairs of RCA inputs on it. It's a Bazooka sub/amp enclosure combo.
So hypothetically if I were to be able to reach the back of the headunit, I understand it should be as straightforward as it was installing where I have it now but I fear that I may possibly have one of those headunits I see on crutchfield.com that only have 1 pair of RCA inputs. If that is what I have, instead of 2 pairs, what would be the diagnosis?
  • Who's Online   0 Members, 0 Anonymous, 3172 Guests (See full list)
