troy Posted April 7, 2009 Report Posted April 7, 2009 kenwood 9103d is the amp one ohm stable and what are the ratings on the amp??? retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
raytard Posted April 7, 2009 Report Posted April 7, 2009 Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] - Audio Section Built in variable Low-Pass Filter 50Hz-200Hz, -24dB/oct Built in Low-Pass Filter - Built in variable High-Pass Filter - Built in High-Pass Filter - Built in Infrasonic Filter 15Hz or 25Hz, -18dB/oct Wired Remote for Bass Boost - Built in Bass Boost Control 40Hz [0dB-+18dB] Phase Invester 0°C [Normal]-180°C[Reverse] * Frequency Response [+0dB -3dB] 5Hz-200kHz Signal to Noise Ratio 100dB Input Sensitivity Control 0.2V-5.0V Input Impedance 10k Ohms Operating Voltage [11-16V] 14.4V Current Consumption 40A K-STAT - Dimensions W x H x D [mm] 380 x 64 x 286 Weight [kg] 4.1 it says 1ohm stable, but its not listed in the specs, so i assume it will run at 1, but not very well also says "40 amp" consumption, its fused at 60 amps id say maybe do 600 at 2ohm, and 1ohm is out of the question guess your 1000@1ohm thing is harder then it appears...why not just save a bit of cash and get an amp that'll do it at 2 ohm or 4 ohm? http://www.sonicelectronix.com/item_12249_JBL+GTO14001.html cough cough run it at 4 ohm, get your power and then some, clean, no worries, and it wont even get above room temperature at 4 ohm, even blasting all day. Even at 2 ohm after 8 hours full tilt mine stays cooler than my headunit screen.... i know you're tight on cash, pick some pennies and save a little, 1ohm is scary territory with lower quality amps. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
troy Posted April 7, 2009 Author Report Posted April 7, 2009 any opinions on the hifinics bx1206d? retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Zade08 Posted April 7, 2009 Report Posted April 7, 2009 I ran that amp on my 2 kicker 12s at 1ohm with no problem. Only thing I will say is make sure you have the juice to back it up. that amp doesnt like low voltage. If it drops below like 11.9 it will kick into protect. One of the best sounding amps Iv ever owned though. Vehicle: 2001 Ford Escape Head Unit: Kenwood Kdc-x592 All out for a rebuild. New shit coming in the next 30 days.
troy Posted April 7, 2009 Author Report Posted April 7, 2009 I ran that amp on my 2 kicker 12s at 1ohm with no problem. Only thing I will say is make sure you have the juice to back it up. that amp doesnt like low voltage. If it drops below like 11.9 it will kick into protect. One of the best sounding amps Iv ever owned though. the hifonics or the kenwood? retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Zade08 Posted April 7, 2009 Report Posted April 7, 2009 the hifonics or the kenwood? The kenwood. My bad. Vehicle: 2001 Ford Escape Head Unit: Kenwood Kdc-x592 All out for a rebuild. New shit coming in the next 30 days.
troy Posted April 7, 2009 Author Report Posted April 7, 2009 any better opinions than the two? retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
troy Posted April 8, 2009 Author Report Posted April 8, 2009 does anyone have anything other than the kenwood or hifonics? retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
The enD Posted April 8, 2009 Report Posted April 8, 2009 does anyone have anything other than the kenwood or hifonics? http://www.stevemeadedesigns.com/board/ind...c=41500&hl= Lots of replays on other brands... yeah I see it's your thread.
