Ground them to the chassis.
But I wouldnt wire them to the remote wire unless you use a relay.
Give em their own dedicated switch.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
u mean give them their own fuse? bc i just have my remot wired into one of my fuses in my fuse block
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
I would take that remote out of the fuse box too.
What fuse is it?
You should give any accessories that you add on, its own dedicated fuse and switch. The amps can just be wired to the head unit's remote wire. If you have a factory head unit. Run your own power wire from the battery of master power through a switch.
Ed Lester
ShowtimeSPL Host
My old Build Log
What fuse is it?
oh really? i thought i could just run the remote to a fuse in my fuse box such as the powerwindows fuse. it hasnt caused any problem yet but i have a alpine head unit< i guess i could just wire it to that. could i run the led to the kinetik batt that i have in the back with a switch on it?
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
yeah, if you can go to the battery that will work really good.
Then just ground to the metal of the car.
You may not have had any problems, but its not the best thing to do, especially if you plan on adding amps. And sometimes you can have turn on pop if the amps are turned on/off with ignition or something.
Ed Lester
ShowtimeSPL Host
My old Build Log
ok cool sounds good
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
Kinetik
Oznium has a tutorial section on their forum full of very detailed and illustrated instruction for all of their products.
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
