Ok so i just put my new system in and when i wired everything in i put in an HC800 in the back and also did the big 3 upgrade but am still seeing dips in voltage down to from 14.2-11.6 at 2000 rpms, do i need a Bigger battery, or Bigger battery and alt? cuz im only running my 1400.1 at 1 ohm and i didnt expect voltage dips like that from a smaller amp like this.
2000 White Dodge Durango 5.9L
Flowmaster 40 Series through 2 1/2" with and open cat.
1 Dc lvl5 18
4 6.5 seleniums and 2 D200 Selenium Horns on Rockford 500.2
Big three upgrade and a kinetik HC1800 in the back with all 1/0g knu wire
shootin for 145+ :)
im havin same probs man. im tuned in
Yea i really figured that with the amp i running, doing the Big 3 and an extra battery would help. If not them im pullin this all out and goin big lol.
1 Dc lvl5 18
shootin for 145+ :)
What battery do you have up front?
umm shit its a wal-mart 800 or 875 cca iirc.
1 Dc lvl5 18
shootin for 145+ :)
I was having the same problem 2 weeks ago so I had the battery tested and it came back fine but I knew something wasn't right so I pulled everything out and started over and it still done the same thing then I changed the front battery out for a kinetik HC1400 and after that it doesn't drop below 13.3 but at this time its hard to tell since I fried my good amp but that worked for me.
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
do you know the draw on the amp and what the alt puts out
Idk what the amp draws i imagine either a little over or close to 100 amps at full tilt, and my stock alt is 120 amps iirc
1 Dc lvl5 18
shootin for 145+ :)
