scottiej Posted April 13, 2009 Report Posted April 13, 2009 Kinetik does not recommend using the HC600 or 800 for starting. Check the chart below to properly choose which battery to use as either the primary (only battery in the vehicle) or secondary (used along with OEM battery). http://www.4xspower.com/caraudio.html Quote XS POWER Batteries, Chargers & Accessories 888-4XS-POWER
soundzright Posted April 13, 2009 Report Posted April 13, 2009 Looking for a cheaper starting battery get a deka intimidator Quote
brewer_brewer Posted April 13, 2009 Report Posted April 13, 2009 he said to get a hc600, and thats what is for sale on that ebay page. i use a single yellow top in my car and im noticing that my voltage can not go higher than 13.1 Volts. I've heard that yellow tops dont go much higher (voltage wise) for some odd reason, where as a kinetik or powermaster battery will go to 15+ volts if done correctly. if you want a very "strong" battery, then stick with the kinetiks or powermasters! are you talking about what voltage your battery floats at or when its charging? optima's will float between 12.4 to 12.9. but they will charge to 15+ Quote REFS http://www.caraudioclassifieds.org/forum/itrader.php?u=2026 http://www.stevemeadedesigns.com/board/topic/44535-official-brewer-brewer-feedback/page__p__625998__hl__brewer__fromsearch__1entry625998 "you're not allowing natural selection to work, you're like the guy that invented the seatbelt"
monoxide Posted April 13, 2009 Author Report Posted April 13, 2009 i just pmed him but i dont think i can afford his battery yet. i only have like 100 bucks for one. Quote
