Rockford Fosgate 2600x
uhoh_45
anyone know any info on this amp
i bought one off my buddy he had it layin around and the back of it i cant read anything on it
this amp
Posted Image
im really just looking to see how the crossover chip works and how to wire my tweeters 3 single 4 ohm tweets
would this amp handle a 1.34 ohm load? or should i go with the 12 ohm load
R.I.P!
(Nov-29-2009)
92 explorer
current build
I have that same amp. Its amongst my first gen punch amplifiers. I'll dig it out tomorrow to make sure but I belive it 15W or 30W rms X2 at 4ohm,but I'm not sure. I tried to run some alpine Type S full range speakers but, I could only get about 20 minutes before it would overheat and turn off. I'll post a picture of ratings on back tomorrow. It sounded good and I'm pretty sure it would run some tweets with ease. I'll do it tomorrow cause its kinda buried.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
i found one on google of the back of the amp
Posted Image
60 x2 at 2 ohms... i just wanna know if it would run at 1.34 ohms?? and how the crossover chips work?
R.I.P!
(Nov-29-2009)
92 explorer
current build
Sorry, I lied to you. I have a 2300X, which is 30Wx2 at 2ohm. Well, the old school amps were pretty tough. All I can say is try it. Mine does not have a crossover chip like yours so i can't really help. I'll bet it could handle 1.3 ohms, but you'd have to keep it cool. Because mine got hot fast, being below stability could cause more excess heat. How much did you pay?
It's all gone!
The Celica Build
Feedback
thanks alot for manual and i payed 40$ for the amp
R.I.P!
(Nov-29-2009)
92 explorer
current build
