New Build 2 10" Hdc3 +aq3500d Amp **UPDATED**
Whats the specs on the box looking like?
I want to see this done as well
the box is going to be a solid 3.5-3.8cuft depending on what i can squeeze out of that damn truck. ports will be on the passenger side with 17'' of port outside the box pointing up at the roof. will be tuned to 32hz with a length of around 62'' and 15'' in height. my main task is my side panels in the back, i may need to cut them so the box fits better.
will be leaving on vacation friday and wont be back till the following weekend. when i come back i will be hard and heavy on the project and should have new build pics coming soon. got the passenger door to finish, box, little wiring, and im done http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
As long as you are right at 62 inches it should squeeze in there. Mine is 62 and an 1/8 and that 1/8 of an in made it tuff to shove in there, but it fits good.
Posted Image
Posted Image
93 Chevy Silverado
Crossfire,Dayton
Soon to have 6 Lvl4 15s
DC Audio Dealer and Team Member
I like what you did with those front door enclosures. I'm gonna have to do the same in my Monte, i'm trying to pump myself up into believing I can handle it....not quite there yet.
Alpine CDA-117...Memphis 16-X03
CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6
Soundstream Rubicon 1.2500d...Digital Designs 3512f
was my first time ever to touch fiberglass and reasin. not hard, just use ur commen since when mixing it and dont put like a shit load of hardener bc it will get hot fast on you. came out ok for my first time doing it though, i was happy. it served it purpose of blocking any water that leakes through the doors. wasnt looking to make it spotless clean looking since nobody will see it
1 3500d AQ amp
alright well went and got the wood today. sucks bc its up to like $26 a sheet here. anyway got most of the box cut out today but that small opening u will see when i put the pieces together. i might fiberglass that part or cut out wood for it to fit, havent decided yet. box is 3.5cuft after all diss of subwoofer and ports. will be using 3 4'' flared ports with the port being 27.5'' long each and i will have 17'' of each port being out of the box to save on cuft disp.
got to hot today so ill start up on some more work tom with the build. advice and comments are welcome
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
1 3500d AQ amp
i wish it was 26 a sheet here
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
i guess i should feel lucky then. use to be like $20 a sheet for 3/4mdf but whatever. do what u got to do to have bass
1 3500d AQ amp
damn right u better feel lucky at $26 a sheet. im in canada and prices are thru the damn roof here i paid $12 for a 2' x 4' piece of 1/2"! :censored:
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
lol ok ok guys i feel lucky....didnt know it was that bad around places
1 3500d AQ amp
its 29 a sheet here but used to be 19...
2007 Chevy HHR LT
UNDER CONSTRUCTION
