Coolwazabi Posted April 16, 2009 Report Posted April 16, 2009 Well i lost my gasket to the woofer... and it leaks a lil air.. alternatives ?
Stephen Posted April 16, 2009 Report Posted April 16, 2009 Well i lost my gasket to the woofer... and it leaks a lil air.. alternatives ? weather stripping? you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
flashlight_65 Posted April 16, 2009 Report Posted April 16, 2009 a small bead of silicone on the box perhaps? My builds: my caddy my 'hoe friends impala
uhoh_45 Posted April 16, 2009 Report Posted April 16, 2009 ductape on the outside to seal it R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
CaptainzPlanetz Posted April 16, 2009 Report Posted April 16, 2009 ductape on the outside to seal it Just one of the many great uses for ductape ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
