well my crunch pzi 1500.1 amp came with a bass knob. when the amp is on there is a little green led that also comes on, when i turn push it full tilt it turns to red slightly on harder hitting tones. does this mean im clipping when it turns red?
2002 FORD EXPLORER PACKED WITH SOME CHEAP SUBWOOFERS!
yea exactly. dont turn it up to the point where you clip or you could damage things
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
Yep - red indicates clipping (or almost) on the transients). Quite a few decent amps light their clip LED 3db or so before clipping actually occurs - the older Jensen ones used to do this. You can safely run those with the clip LED flickering, but you're dangerously close to DC.
  • Who's Online   0 Members, 0 Anonymous, 3237 Guests (See full list)
