I have a 2000 Chevy Silverado I been wanting to hook up. I got my head unit which is a Kenwood Excelon X-692 and a Kenwood 1000 watt amp goin to my Infinity Kappa door speakers. 6 1/2 and 3 1/2. Now under my back seat i have a custom box that i wanna put 2 Fi Bl 12" woofers. Powered by 2 Kenwood 2400 watt max KAC X1R amps. What i wanna know is that if i have 6000 watts pumping (Ill have capacitors) if i will need a high output alternator and new battery? If so what kind?!?!?!
2000 Chevy Silverado ext cab
Kenwood Excelon X-692 Head Unit
Kenwood Excelon KAC-X20 Amp Wire to Alpine Type R 12" 2ohm
Infinity Kappa 6.5" and 3" pushed by rockfored 400.i? or something? I'll look later. Its 2 amps in 1
First off I dont think those kenwood amps are gonna do 6k watts, but ditch the capacitors, and just go with an extra battery, or 2 if your pushing an actual 6k watts you would need to upgrade to a HO alt and 2 or 3 batteries I would say.
EDIT: For batts, Kinetik, Powermaster, almost any sealed G31 battery
Edited by E-Train
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
Well first off, chances are, the BLs will sound like shit UNDER a seat and will probably not be in a box big enough.
2400MAX is not 2400RMS. It won't be 6kW.
Capacitors will be absolutely worthless no matter how many you have.
You will need multiple batteries to handle a 6000W system and one or more big alternators.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
you're gonna have about 3000 rms at the most.
so you could do it with a 200 amp alt, a big batt up front and another big battery in the back.
for starters, caps do NOTHING
second, those x1r amps are good for like 750ish watts, maybe 800 at 1ohm but they get hella hot
third that highs amp is probably like 50x4 (and those kappa 3.5's wont take more than ~35 watts)
so keeping in mind we are working with a like 1800 watt system, not 6000watts:
what does your truck have as far as stock electrical? ive seen some with 180amp alts, dual factory alts, dual factory batts, etc. if you have the dual batt setup, or atleast the 180amp alt, all I would suggest is a nice battery (kinetik, powermaster, etc), the biggest you can fit, just to keep up with the breating
if you find that your lights still dim or the truck has trouble starting after a long day of driving around beating, consider a new alt, try clicking on that dc power banner at the top of the page for some great stuff, also check mechman/stinger/ohiogen/powermaster or any other reputable alt company
Team DC
I have 2 2400 watts max amps for my subs and 1000 for my mids and highs
Thats max bullshit is an inflated rating to make you think your getting that kind of power. The rms rating is what you will actually see.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
like he said, 6000w max is not even remotely the same as 6000rms.
do not waste money on capacitors, just get a good sealed deepcycle battery and your fine
"EDIT: For batts, Kinetik, Powermaster, almost any sealed G31 battery"
Ok considering that kenwood amps are rated at 14v and your running a 12v system. You might see 900 out of that 1200 rms rating. so thats 1800rms there plus around 200 rms from your highs amp you only gettin maybe a little over 2000rms man. All you need is a bigger bat upfront and if your car is a higher end model it might have a bigger alt in it like mentioned up top.
those are really 1200 rms
* Reference Series power amplifier with 2400W output
* Dual sigma drive
* RMS Power at 4 Ohm: 1 x 600 Watts
* RMS Power at 2 Ohm: 1 x 1200 Watts
* RMS Power at 1 Ohm: 1 x 1000 Watts
* Maximum Output Power: 2400 Watts
* Signal-to-Noise Ratio: 80dBA
* Low-Pass Filter: 40-200Hz (Variable), -24dB/oct
* Infrasonic Filter: 15Hz-60Hz (Variable), -24dB/oct
* Variable Band Reject Filter: 40Hz-200Hz, OFF/-6dB/-12dB
* Bass Boost Ready (Wired Remote): 40Hz-100Hz, 0dB�+18dB
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
  • Who's Online   0 Members, 0 Anonymous, 2726 Guests (See full list)
