Problem Setting Amp Gain On 500/1 And 300/4?
neutman21
So I am trying to use JL Audio's tutorial on setting my 500/1 and my 300/4. I got the test tone cd recorded at 0db for 50hz and 1000hz and I tried both amps. 17.3 is my desired voltage on my 300/4 and 38.7 on my 500/1. ( I will be running a 10w7-3). I tried the cd after turning everything off (bass and treble on cd player, bass boost, etc.) and I am not able to get those voltages on either amp. Am I using the multimeter wrong??? what setting on the multimeter does it need to be??? and I am also using an audiocontrol eql and audiocontrol 24xs with each set to its desired inputs and outputs according to the manual. And I even tried to set the voltages on the amps without the audiocontrol units and I got the same turnout....why am I not able to get these required voltages????
THE BASS KICKS AND THE HEADS TURN. THE STEERING WHEEL PULSES UNDER YOUR FINGERS AND YOU MORE THAN HEAR THE MUSIC, YOU FEEL IT. THE CRISP, CLEAR SOUND JARS THE COMPLACENCY FROM YOUR SOUL AND LEAVES YOUR PROBLEMS SCATTERED ON THE HIGHWAY UNROLLING BEHIND YOU. HERE IN YOUR CAR, YOU ARE KING. THIS IS YOUR WORLD, YOUR TIME, WHERE YOU ARE THE STAR AND YOU PICK THE SOUNDTRACK…
Alpine CDA-9887
Audiocontrol three.1
JL Audio xd400/4
JL Audio C5-570 Components
JL Audio C2-570x
JL Audio hd750/1
JL Audio 12w6v2
Optima Yellow Top
Viper 350hv
You want the AC volts setting on the multimeter, probably on about a 50v range if it has one...
10.x volts fo' life!
That worked....Thanks for your help...
Alpine CDA-9887
JL Audio xd400/4
JL Audio C2-570x
JL Audio hd750/1
JL Audio 12w6v2
Optima Yellow Top
Viper 350hv
