Setting Amplifier Gain Control
dbwesz
good info here. Ive got 2 sa2500 starped at .5ohm for me is it square root of 5000x.5 and get 35.3? Would I use the positive from master amp and pos from slave amp with the dmm (the negatives are wired together between both amps)or can I just use the pos and neg from the master?
Team DOA
Team gg
Wondering the same thing. I have 2 saz1500's strapped at 2 ohms... No clue where to put the probes from the DMM.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
  • 2 months later...
  • 9 months later...
I adjusted my gain using a chart from a
Formula and used a volt meter and I was
Wondering if i installed a line driver if
I would have to re adjust my amps gain again
8 sundown sa 12s walled
Saz3000 at .5
HO alt
All ofc Sky high wire
Alpine components
Rockford power mids
imagesCAA9EA5N_zps0f411022.jpga5ec9a01-b60c-4312-9001-236b48dfe6b0_zpsb01ef146-7fd0-47c3-90e9-f1a2d4595b03_zpsimagesCATNMRMV_zps66a8566a.jpg
  • 1 month later...
I have a couple of questions on my amp. It is a Planet Audio BB1250.1. It is running 2 Treo SSi 12" dual 4's and is wired to 1 ohm.
First, I was adjusting the gain today by ear and it has the gain setting but also has a input sensitivity switch and you can select either 100mV-2V or 2V-8V. When I switch it to the 2V-8V setting and adjust the gain, there is no difference in output. The subs are playing but very low. Now if I switch it back to 100mV-2V, the gain setting actually changes output. Anyone have any ideas on why there is no difference throughout the 2V-8V setting. The deck is a Alpine 9813. Eq for lower frequencies are either flat or - (which that setting is not being changed during the process) and subwoofer level control at 12 also did not change. If I understand correctly, the subwoofer level control acts as an control for the level output. I have read that the deck puts out 4V with subwoofer level control at 15 but will be less at a lesser setting.
Second, the amp came with a birth sheet that has it at 1251@1 ohm. I don't want to dig the birth sheet up but I believe that the rating was with 12.x or 13.x v of power. The voltage readout that I have at the amp never really goes below 14.0V. Would the rated power be increased, even by a little, with the higher voltage rating or is it the same from 12-14.4V like some amps?
Thanks in advance.
What's up y'all I got the same question as the member above. The input switch when set on 2-8v makes the subs very quite and have no movement. When I set the amp on .1-2v the gain actually makes the subs hit and has a fair bit of adjustment to the amount of output power. Wondering why this is.
I am running a soundstream rub2500.1d @ 1ohm. I just don't want the gains set to "strong" and mess the amp up or make it over heat.
HU:
Bass: 0
Mid:+2
Treb: +3
Subwoofer level: 6/6
Preout voltage: 5v
- 1997 Chevy Tahoe- Big 3 (1/0)- Dual Autocraft Batts- JVC KD-A315 HU- AQ 2200.1D- 18" AQ HDC3- Box w/ Removable Port (6ft^3 @ 36hz & 6.7ft^3 @ 42hz)- 39' 1/0 & 13' 2/0 Flex-A-Prene
My Selling Feedback
Build Log
  • 1 month later...
How do I find out the voltage thing for my 2011 zx1500.1. I don't see it in the manual anywhere. The one the no video says to get
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
  • Who's Online   1 Member, 0 Anonymous, 1968 Guests (See full list)
