white4d96 Posted April 25, 2009 Report Posted April 25, 2009 If I have a 2-channel amp running at 4 ohms bridged, powering two 4-ohm subs, do I have to run wires to just one sub and then from said sub to the other? Can I just run two separate leads from the amp, one to each sub? or will that change the impedance? Too many projects, too little time...
wL<3bass Posted April 25, 2009 Report Posted April 25, 2009 If I have a 2-channel amp running at 4 ohms bridged, powering two 4-ohm subs, do I have to run wires to just one sub and then from said sub to the other? Can I just run two separate leads from the amp, one to each sub? or will that change the impedance? No but running to single 4ohm coils = 2ohms. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
white4d96 Posted April 25, 2009 Author Report Posted April 25, 2009 Oh, okay. How can I wire them then? Cuz I was told to do as I said above (wire to one woofer then from woofer to woofer) but I can't get the two wires that are in one woofer to stay in the terminals. Subs are DVC 4-ohm and using 12-ga. speaker wire, if that helps. Too many projects, too little time...
15VmaxXL Posted April 25, 2009 Report Posted April 25, 2009 Oh, okay.How can I wire them then? Cuz I was told to do as I said above (wire to one woofer then from woofer to woofer) but I can't get the two wires that are in one woofer to stay in the terminals. Subs are DVC 4-ohm and using 12-ga. speaker wire, if that helps. If they are DVC then you have it wired to 1 ohm. Ohms / Number of drivers = ohm load. If wired in parrael. if you cant fit the wire in the speaker teminals its fine to run 2 wires out of your bridged amp. sold everything
white4d96 Posted April 25, 2009 Author Report Posted April 25, 2009 If they are DVC then you have it wired to 1 ohm. Ohms / Number of drivers = ohm load. If wired in parrael. if you cant fit the wire in the speaker teminals its fine to run 2 wires out of your bridged amp. According to the diagram from the manufacturer's website, my current setup has them set at 4 ohms each. Too many projects, too little time...
myveryown07 Posted April 25, 2009 Report Posted April 25, 2009 a dvc 4 ohm sub can't be wired to 4 ohm by itself. it can be put down to 2. and wiring them together would give you a 1ohm load. what are you trying to do?
white4d96 Posted April 25, 2009 Author Report Posted April 25, 2009 Okay, I was wrong, each one is wired to eight. combine the two and you get a 4-ohm load, right? Too many projects, too little time...
BJD3 Posted April 25, 2009 Report Posted April 25, 2009 Two Dual 4 subs can be wired to four ohms. Anti Peel and Seal...lol You may be offended by the above. Don't take it personally, I'm just abrasive. 2002 Buick Park Avenue DC Level 4 M2 12 D2 Car Audio Bargain 1600.1 Eclipse CD3200 ~2 cubes @ 34 hz. Stinger Roadkill Expert
