Retracted Not! Another 150+ System
Yeah I hear ya on the fanning issue! Not my style either. Where are you going to be at next weekend? If I am free I will stop by and introduce myself.
1999 Chevy Tahoe
Level 4 15"
AP 3000d
Rockford and Phoenix Gold Componets
T400.2
Mechman 250 amp Rhino
2 Kinetik 2400
GET LOUD : STAY LOUD : SLAP RESPONSIBLY
Planning on trying for the Loud-N-Clear event on Saturday, but definatly at the Import Face Off at KCIR on Sunday.
I drive the 08 Kia Rondo, this one:
Posted Image
Team Soundstream
Team Optima
Team HK
2 Soundstream SPLX-152HX
2 Soundtsream TRX2000D
1 Soundstream RUB4.600
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream S-Cell400
1 Soundstream Power Plant
1 Soundstream BX-15
1 VMAX CT1900
2 Optima Yellow Top D34/78
1 Kenwood KDC-X493
Posted Image
Yeah I seen that soundstream monster. Really clean install! You gotta give me a demo in that thing! But I will deffinetly be there on Sunday to check things out.
1999 Chevy Tahoe
Level 4 15"
AP 3000d
T400.2
2 Kinetik 2400
Sweet se ya there hopefully, no prob on demo. I'm always willing to let someone check it out, but only after run is over.
Team Soundstream
Team Optima
Team HK
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream BX-15
1 VMAX CT1900
1 Kenwood KDC-X493
UGGHHH Did no one else Notice the Wet Battery inside the car and the Ground that is screwed down with multiple screws then solder slopped on top of it?
Wow you said the other install was not up to YOUR Standards but THIS is? Wow Sorry but that is plain wrong man.
looks more like a shitty pic of a ground lug to me
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
I think that most of your problem is you are tuned way too high I had an SPL enclosure in mine tuned to 50hz or so and it always burped at 43hz then I got another box that was tuned for music and accualy that was worth 2-3db
OK ground pic is crap, we all got that. And what the hell does he mean multiple screws? there are 2 screws just like anyother ground I have ever seen then heat with torch and solder to frame to ensure solid ground. What the hell else woould you resommend? put some pretty carpet under it and primer and paint it? It's a freakin ground people you want a solid connection if you're not going to run a solid wire from batt. I have never had a voltage or loose ground issue from my grounding blocks on any system I have ever built. If you need a better pic I will be sure and get you one if it will stop all the crying. Oh, and yes wet batt is better for a run than no batt last time I checked, until we can get the Charge Tanks in.
Team Soundstream
Team Optima
Team HK
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream BX-15
1 VMAX CT1900
1 Kenwood KDC-X493
WOW maybe you should step back and take a breath before you say something you cant take back. Ok the ground block is screwed to the body and then you heated up that and slopped solder around it. I can see it now. I would not ever run a wet battery in my car. But I understand you had to show off the car and were impatient. Thats understood. By the way what did YOU do for a score? you said your meter was way off compared to the USACi one. I am not crying I will however not praise slapped together or rigged work. sorry
He hit a 143.7 db in Trunk 1001-unlimited
Team Soundstream
Team Optima
Team HK
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream BX-15
1 VMAX CT1900
1 Kenwood KDC-X493
