Pioneer~Saturn Posted May 12, 2009 Author Report Posted May 12, 2009 Thanks Alright, it's starting to look more complete Made a piece to go across the opening to level it off with the rest of the front chamber/section.. Mounted.. The wall of mirrors (random).. Got the other side panel mounted tonight too...got the holes drilled for mounting.. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 12, 2009 Author Report Posted May 12, 2009 Mounted.. A few over-view pics of everything.. Got a piece cut for the corner area of the side...and another but no pics of it.. Those will go in tomorrow ...more then Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
zfrerichs Posted May 12, 2009 Report Posted May 12, 2009 im guessing birch and you own a table saw Roseville, CA
knowledge Posted May 12, 2009 Report Posted May 12, 2009 lol REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
Pioneer~Saturn Posted May 12, 2009 Author Report Posted May 12, 2009 Haha, yes I rent out a 2.5 car garage that I have a shop set up in...table saw etc. that I'd need for wood. And yes, birch. And I got some work done before work today but cant upload pics here pics later tonight Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 13, 2009 Author Report Posted May 13, 2009 Alright, got some stuff done before and after work... Got some beast terminals.. Planning to put them on this piece of the enclosure for easy access.. Mounted.. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 13, 2009 Author Report Posted May 13, 2009 Last piece cut for the main chamber :veryhapp: Angled piece (well, this would be the last piece..lol) Overview As you can see, though , there is a slight flaw that will have to be worked out... In making the two sections (port and main chamber) meet in the middle...they werent exactly the same and were slightly different angles. So you can see in that last pic the piece running across is about 3/4" higher on the driver's side...that will need to be cut and sanded down to make flush, not a huge issue but I wasn't the happiest about it when I saw it coming together. Tomorrow should have some fiberglass and body filler action...more then Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Torres Posted May 13, 2009 Report Posted May 13, 2009 nice! looks like it's all comin together nicely
Pioneer~Saturn Posted May 13, 2009 Author Report Posted May 13, 2009 Thanks Yea, it's starting to be about that time Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
Pioneer~Saturn Posted May 13, 2009 Author Report Posted May 13, 2009 Today I should be able to hopefully get the body filler portion done and everything sanded...then move onto fiberglassing and then if time allows, get the port finished up and the back of the port on to get ready to mount the amp etc. Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..."
