I was driving around town for a while running errands, i DID use the bass knob turned about 1/2 way. However i set the gain with the bass knob all the way up so i didnt "over power" the sub. I have a 12 Fi Bl w/ cooling. Its getting about 1375 watts at about 14 volts. Should i be worried ?
Increasing bass boost increases clipping... which increases power. Which also increases the heat production.
Turn your Bass Boost on your headunit and amp to 0. I blew two Type-R's this way.
Always measure your voltage too.
he tuned the gain with the "bass boost" up he said.
besides that RF is different. its not a bass boost its a frequency booster.
a little hot shouldn't matter as long as you are not continuously doing that.
and are you still breaking your sub in?
Wouldnt be thehoe92 without teh purple
I dont think im still breaking the sub in. I have had it since about mid march. I dont always have the bass boost up, but i do ride around with it all the way up for a couple minutes at a time. and i didnt use the bass boost on the H/U, i used the bass knob.
THis sounds really dumb but how hot is hot? Was it too hot to touch?
It was warm not like scalding hot, but warmer than i have ever felt a sub.
hm...i would double check that you aren't clipping if you can.
About how long was it goin?
Probably in total around an hour of driving. Stopping at a shop, then go, then stop, then go. Overall prob about an hour.
mine will also get warm from time to time.
a lot of times its what song I play and which notes are in it and if the song possibly has clipping.
you shouldn't be too worried if you don't smell them then you aren't pushing them too hard.
and if you smell them?!?!
hahahaha
i like that smell..
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
  • Who's Online   0 Members, 0 Anonymous, 1746 Guests (See full list)
