how do you measure the over all length of a ninety (elbow) using port tubes and need to bend them out but not sure how to calculate the over all length. using four inch tubes ,do you measure the diagonal from corner to corner ? not sure .
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
take a piece of string, put it dead center and follow the curve. measure the length, subtract the amount of straight pieces inside of the elbow, and you have your length.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
little different question...but what about if some if ur port is outside the box...like bassbox pro 6 has an option for no flush ends... because 6" port needs to be 6" from enclosure wall correct?
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
It needs to be no less than the port diameter distance from the wall.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
when you say dead center do you mean dead center out side back wall or dead center inside of elbow ?
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
so its okay to have it outside the enclosure some?
still got da cavy?
Stock Highs
Stock Electrical
AP1500D
bent-double.gif you want the area that's dotted, measure that.
It is ok to have it outside of the enclosure, just means it doesn't displace inside the box :)
I have a cavfire, yup, still got it. Haven't had it on the road in about 2 years, but it's just about ready for inspection.
Edited by lanman31337
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
thanks for your help on the measuring , now i ran into another problem. i originally bought six four inch psp aero ports that i was going to use but once i got into this build i found out i could only use four. today i get ready to set the ports and found out that with the standard PVC nineties i only have about one inch to a 1 1/2 from the bottom of my tub so now I'm worried about port noise . not sure if i should lift the ports out of the box a little or just run with them the way they sit. this damn box is fighting me all the way .
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
If it's going to be close, run them outside of the box.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
