Need Help With Cutting!
JasonJones
Ok... So after a long series of events and mistakes my 2 Fi BTL 18"s are coming tomorrow. Have all my wiring done(Only a few electrocutions one from putting the positive coming from the alt to the negative terminal on the bat!) T4k is hooked up and I'm idling at 14.75~ volts. So all is well right? Wrong... I took it upon myself to try to make my box. Now the problem is I fucked up a couple things, first not having a table saw and having Home Depot cut my wood... Guy ended up cutting the side lengths 3/4 of an inch short... Second mistake was gluing/screwing the box before noticing the mistake... So my choices were either lose a third of a cubic foot of airspace or deal with it. So I said fuck it and this'll be my test box for now and maybe build a better one down the road.
Now my question for you guys is HOW THE HELL do you measure and mark a semi-perfect circle to cut the ports for the subs? My Home Depot/Lowes are fawking ghey and don't have large drawing tools or whatever their called... And I tried the old "Put a screw into the middle and use a string and pen".... That really didn't work it ended up more like an egg shape! I guess I suck.... Anyways halp!
i use a tack a peice of cardboard and a pencil. just measure the two holes the radius of your cutout apart
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
get a good drafting compass. they work great.
01 s10 blazer 6 jl12w6's
same i use a peice of wood
lol. but i haven't and i don't plan on it. plus i'd probably miss and hit her belly button or her ear or something. lol.
hole saw from lowes... put it on your drill and make perfect holes... you may spend 20 or 25 bucks on it but you can use it over and over and over....
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
i use the plastic ring off of the subs trace the inside but oldit down and draw lightly first so ring doesnt move
Kenwood Excelon DDX812 6.95" double din
4 lvl 4 xl 15"
4 RF 1500
2 RF 600.4
2 15-MC5 - Memphis 5.25" 2 Way MClass Coaxial Speakers
2 15-MC92 - Memphis 6 x 9" 2 Way MClass Coaxial Speakers
2 mc memphis tweeters
memphis 16-EQP4 Signal Processors
4 2400 Kinetik
1 1800 Kinetik
iraggi 300
http://www.stevemeadedesigns.com/board/ind...showtopic=42009
  • Who's Online   0 Members, 0 Anonymous, 571 Guests (See full list)
