quick question. i dont need any side topics or none of that shit but do u put + and + on ur Cap. wen uhook it up. Split the battery then line it str8 through. then put it to ur amp..? like this = wire coming from batter--> (battery)------[]--[]----(amp)
Edited by BassHead7
Gota have my rear view shakin and my seats vibratin'.
(2) 12" Diamond D3
(1) DEI Directed Audio 2400D
(1) Kicker L5 15"
(1) Rockford Fosgate P5002
(2) 12" Fosgate P2's
(2) 15" Fosgate P2
^^Not all hooked up at once, i rotate. Its all i got.^^
First thing you have to do is charge the cap. You put the positive from the battery to the positive on the cap. Then take a 12 volt light bulb and touch the bositive on the cap an the negative on the cap. Make sure your ground wire from your cap goes to the same ground as your amp. once the light bulb dies that means the cap is fully charged.
And to wire it heres a diagram
BATTERY++++++++++(cap)+++++++++amp
Then the negative just goes to the same ground as your amps ground. Hope that helped. J.W wat cap do you have ???
Edited by civichatch
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
ok o the wire from Batt. to Cap. to Amp. goes on positive Only. then ground goes on negative ONly. or Batt. goes on both. btw its a RF cap. i think a .5 or sumthin im not sure but need it while i save up for a new battery lol
(2) 12" Diamond D3
(1) Kicker L5 15"
(2) 15" Fosgate P2
The negative on the cap doesnt get connected to the amp at all. You just run the negative to the same ground as the amp uses. (same peice of metal u used to ground the amp)
And yes you dont run a negative from your battery to your cap. Unless you have already run a negative line off your bat.
System Specs:
MTX Bass Knob
80 amp stinger fuse
My stinger kit's instructions told me to do it this way and so did Best Buy wen i bought it..
Heres a link it shows wat im talking bout: http://www.caraudiohelp.com/car_audio_capa...nstallation.htm
I may be wrong though and if i am please tell me becuase that means my cap isnt even beeing used lol..
System Specs:
MTX Bass Knob
80 amp stinger fuse
You want the cap connected as close as possible to the amp to deliver those last second power surges when the amp needs it. So short power cable to the cap positive to the amp positive cable and also short connection between grounds. Ideally just get a distro block that hooks the cap inline with your power and ground cables. I dunno about others here but I'd always run a dedicated ground to your amps if you're running a lotta power. I wouldn't trust just the sheet metal, especially as the car body ground strap up front which connects the neg terminal of the OE battery to the chassis is usually not the largest gauge. No sense in running 1 gauge power cables and trying to rely on a pencil-neck ground strap to return the currect. :lol:
Like this: capdiagram.gif
Edited by westvan_dude
Ok good that is exactly how i have it and mine is foot away from amp.
System Specs:
MTX Bass Knob
80 amp stinger fuse
wut r those blocks in the center tho. eliminate those. lmao. run positive from batt. to caps positive. then to amp. then ground the Neg. off the cap to metal. i got it now thanks for the help lol
(2) 12" Diamond D3
(1) Kicker L5 15"
(2) 15" Fosgate P2
  • Who's Online   0 Members, 0 Anonymous, 4546 Guests (See full list)
