If This Is Happening....new Alternator?
So I just installed my w7 after not having subs for awhile. Before I hooked it up, I set my amp to JL specs and have the gain half way up at the desired voltage of about 38v, which means I am getting the correct output voltage....put sub in and it sounded pretty good (just need a better built box). Once I got on the road, the output was cut in half and the performance of the sub sucked...I figured I was loosing voltage and that I have not had a chance to check my voltage while the truck was on, right now, I have 3 amps...a jl 500/1, jl 300/4, and an alpine mrp f250. Will I need a new alternator to run all of my equipment to get the output I need??? and how big of an alternator would I need?? Right now I have an optima yellow top, so the battery shouldnt be the problem... Thanks.
THE BASS KICKS AND THE HEADS TURN. THE STEERING WHEEL PULSES UNDER YOUR FINGERS AND YOU MORE THAN HEAR THE MUSIC, YOU FEEL IT. THE CRISP, CLEAR SOUND JARS THE COMPLACENCY FROM YOUR SOUL AND LEAVES YOUR PROBLEMS SCATTERED ON THE HIGHWAY UNROLLING BEHIND YOU. HERE IN YOUR CAR, YOU ARE KING. THIS IS YOUR WORLD, YOUR TIME, WHERE YOU ARE THE STAR AND YOU PICK THE SOUNDTRACK…
Alpine CDA-9887
Audiocontrol three.1
JL Audio xd400/4
JL Audio C5-570 Components
JL Audio C2-570x
JL Audio hd750/1
JL Audio 12w6v2
Optima Yellow Top
Viper 350hv
when you turn the car off does the problem go away? if the problem doesnt go away i would say its just a bad connection. something got loose on your drive.
Somewhat...I tested my battery with a voltage meter with my system cranked while the truck was running and i was getting at least 13volts from the battery....so I don't think its an alternator problem...
I haven't been able to find out why this w7 isn't running right...I figured it was the box, the JL dealer told me it looked small...but I did my calculations and its at 1.34 cubic feet...which is a little bigger then JL's requirement at 1.25, will this make much of a difference??? I know this w7 can make better sound...it seems like it kind of pops when I put my head close and listen and it only gets loud on lower frequency bass.
Alpine CDA-9887
JL Audio xd400/4
JL Audio C2-570x
JL Audio hd750/1
JL Audio 12w6v2
Optima Yellow Top
Viper 350hv
Could it be the low pass setting?
I haven't a clue, but being that its easy enough to check, I figured it can't hurt.
Though that wouldn't affect the volume dropping at speed.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Guest KyleCannon
Check your grounds too! I remember that happening to me when a ground was loose.
Ground looks good, but it wouldn't hurt to make a new one...if it was my ground, would I still be able to get the voltage I need without a huge turn on the gain??? Im thinking about adding a line driver to see if its my input voltage that is causing the problem... i tested the gain with test tone cd and I was getting an input voltage of around 2.75 volts... but that is with the music at max volume and subwoofer setting all the way up...
Alpine CDA-9887
JL Audio xd400/4
JL Audio C2-570x
JL Audio hd750/1
JL Audio 12w6v2
Optima Yellow Top
Viper 350hv
Guest KyleCannon
Line Drivers never hurt. I got an Audiocontrol Matrix and that thing rocks. I love it.
ya... I am looking at JL's line driver...it includes a knob that i can use as a bass knob...
Alpine CDA-9887
JL Audio xd400/4
JL Audio C2-570x
JL Audio hd750/1
JL Audio 12w6v2
Optima Yellow Top
Viper 350hv
  • Who's Online   0 Members, 0 Anonymous, 1043 Guests (See full list)
