so we are trying the 12 l5 and when we hit the hard notes the sub makes a rattling noise like rattling plastic. What could it be?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
loose dust cap?
DC.jpgDC POWER
idk everything looks ok we turned the gain down and rewired everything. Could it be the voice coil?
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
try it out of the box playing free air to locate the rattle
BIG PYMPIN IS BIG PYMPIN IS BIG PYMPIN
common issue on that sub is the heat shrink from the lead slap's against the cone for a long time, and eventually the heat shrink has a long gap in it, with that gap, the lead slaps around like 4 times as much, causing more problems. The heat shrink is in this case on these subs a preventative measure for the leads slapping, but nothing lasts forever
Look at your leads, see if you can see what I'am talking about
lol.
Kickers sound like plastic you see!
I always tell everyone in the chat rooms this!
  • Who's Online   1 Member, 0 Anonymous, 3315 Guests (See full list)
