zacht214 Posted May 9, 2009 Report Posted May 9, 2009 i got i quick question my amp cut out all of a sundden today and ive found that it has to do with the remote wire. is it possible the terminal on the amp went bad. is that even possible? or is the remote wire that im using is it to small its this brand i know its shity and cheap so im thinking that might be the problem, if it matter also it will try to turn on like the Crunch lights will turn on for like 1 sec then turn off. its a crunch p1400.2 2 15 RE SE 1 Audiopipe 1500d Sony HU Batcap 800 in the back Team Tex~Flex
Armoredhaulin Posted May 9, 2009 Report Posted May 9, 2009 i got i quick question my amp cut out all of a sundden today and ive found that it has to do with the remote wire. is it possible the terminal on the amp went bad. is that even possible? or is the remote wire that im using is it to small its this brand i know its shity and cheap so im thinking that might be the problem, if it matter also it will try to turn on like the Crunch lights will turn on for like 1 sec then turn off. its a crunch p1400.2 Easy way to help figure out the problem is to disconnect the remote wire you have connected now. Jump a wire from the +12v power terminal on the amp into the remote terminal on the amp. This will turn the amp on...or it should...if it doesn't come on or cuts out the same, then it sounds like the remote terminal on the amp is bad. If it powers on and stays on without issues then either the remote wire itself might be bad or the remote turn-on circuit on the head unit might be bad. "I don't bullshit. I do what I say & say what I mean." http://www.cardomain.com/ride/2925230 http://www.armoredhaulin.com
Nightshade Posted May 9, 2009 Report Posted May 9, 2009 or the remote turn-on circuit on the head unit might be bad. If this is the case you can then switch your remote wire at the back of the deck from the blue wire to the switched 12 volts wire which would be the red one. It does the exact same thing as the blue wire except that the blue one is just for turning on external amplifiers or other devices that require power only when the deck is on. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
zacht214 Posted May 9, 2009 Author Report Posted May 9, 2009 Easy way to help figure out the problem is to disconnect the remote wire you have connected now. Jump a wire from the +12v power terminal on the amp into the remote terminal on the amp. This will turn the amp on...or it should...if it doesn't come on or cuts out the same, then it sounds like the remote terminal on the amp is bad. If it powers on and stays on without issues then either the remote wire itself might be bad or the remote turn-on circuit on the head unit might be bad. so did the wire from the power to the remote and it did the same thing so the remote terminal is bad, how would i go about fixing it 2 15 RE SE 1 Audiopipe 1500d Sony HU Batcap 800 in the back Team Tex~Flex
raytard Posted May 9, 2009 Report Posted May 9, 2009 a terminal doesnt go bad...either the terminal's conenction to the board went bad (not very likely) or something else went wrong with the amp time to get it repaired most likely....unles you know what you are doing its not reccomended to mess around with it. Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
