I Think I Effed Up
I was wiring a 4 ohm sub to 2ohms so I can I have a 1ohm load on my amp (2 RE se powered by an audiopipe 1500.1d) and I messed up and accidently wired both + to - instead of + + - - ..... I put the subs in the box and cranked it and noticed the sub stopped playing. I opened the box up and switched the wires + + - - the coorect way and it still doesn't work. Is the sub permanetly fucked now cuz I miswired it?
you ain't been bizzy til you've been wit jizzy.
Vehicle:: 2005 Saturn Ion
Headunit:: Jensen 9312HD
Speakers:: RE SE Coaxials
Subwoofer(s):: (2) 15" RE SEs
Amplifier(s):: Audiopipe AP1500.1D
Audiopipe AP1504
Enclosure:: Sealed
Wire: KNU KONCEPTZ 1/0
Battery:: Kinetik HC600
no it should be fine if they was just out of phase you could have sent the amp into protect hope you get this worked out
okay the one sub works fine... but the other one is stiff-like and is not moving..... the amp didnt go into protect and i think it even powered both subs (including the miswired one) for a little until i just stopped working.
Audiopipe AP1504
Enclosure:: Sealed
check the magnet, the glue might have failed a bit and the maynet may have shifted a litttle bit, and is holding the voice coil in place. happened to a 15" mojo i had, dont think thats the prob ur havin tho, but it may be. if the sub dosent move, AT ALL, something is really wrong. can you take pics??
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
shifted magnet FTL
yeah ill take pics be back in 10
Audiopipe AP1504
Enclosure:: Sealed
alright im waiting for the video to upload.... here are some pictures... the magnets are covered up by a rubber thing and i cant get it off... but i noticed that the cone might be separated
separated?
this is a picture of the other side of the sub
Audiopipe AP1504
Enclosure:: Sealed
Audiopipe AP1504
Enclosure:: Sealed
  • Who's Online   0 Members, 0 Anonymous, 2005 Guests (See full list)
