50watts rms should be fine, but its going to depend on how you set up your gains and how loud you actually turn it up. The quarts I have dont require alot of power to be honest, Im running a fosgate 400a4 to 2 pair of comp sets and its at 1/4 gain, I dont need anymore then that. If you want I can get the ac clamp and dmm out to get close to exact power they are seeing.
Gain is not a volume knob....
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
When did I say it was? If you have the gain low and crank the volume, you are going to get a clipped signal and distortion like a b!tch. If you turn the gain up all the way and turn your volume you, it wont be long till somthing is smoked...hints why you set the volume then the gain to safely play where you like it etc.....so what was your post supposed to show?
As far as where you should cross them will depend on your setup, go with what sounds best to you after all its your ride your the one mainly listening to it.
