4 Soundstream 12's In A Standard Cab Dime
Okay, I was supposed to have updates on sunday but didnt, so ill post them now. For the 20 seconds the fuse held my voltage was still way low. I think I need a ground strap from the bed to the frame. Does anybody have suggestions? this is my first time adding batteries.
Batteries In frame, frame bolted down.
Posted Image
Posted Image
Positive wires done.
Posted Image
Ground block
Posted Image
Posted Image
Grounds
Posted Image
Done!
Posted Image
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
  • 2 months later...
So the Lowroll is back for another rebuild. Its been a while since iv updated this so here it goes.
I built this box, & broke the back out (thanks to decafs beats)
Broken mdf & screws sheared off.
So it goes in the old box pile.
Current beat.....
Current System:
Pioneer 6900 HU
Bass:
Yesterday I started teh new box.
Routing out the back wall for airspace. every little bit counts.
Matted & resined corners. Should be strong.
Let me know what you guys think so far!
Current System:
Pioneer 6900 HU
Bass:
why is the back of the box particle board?
Whoa, it is not particle board. Technically it is but its Advantech. We use it at work for subfloors bc its strong as hell & cheap. Im tired of breaking MDF & this stuff is half the price of birch.
Current System:
Pioneer 6900 HU
Bass:
advantech is actualy pretty good stuff and has a 50 year warranty.
Youtube.com/J Hutch22
o ok yea i couldn't tell in the pics. how are you breaking the mdf though?
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
for your ground drill a hole and attach it directly to the frame
oh and as for you breaking your box your using way to many screws there to close to each other and well mdf likes to crumble when that happens
R.I.P!
(Nov-29-2009)
92 explorer
current build
Well, the box was sealed & I guess there was just too much pressure in the box & it just broke the mdf out around the screws.
The ground has been changed since those pictures. It now goes to frame but im gonna run 1/0 from the front battery to those in the rear. I always thought a lot of screws was a good thing. In this new box im trying to do it different with 3/4" front & back panels & have the screws run long ways into those panels. Building box after box isnt cheap.
Current System:
Pioneer 6900 HU
Bass:
looks good so far looking forward to the rest of the progress
Dan Plummer - 1x DC sounds Level4 15" - 800wrms - 3.5 cuft Ported Box - Rover 25
Peak= 142.2dB @ 40Hz
40Hz= 142.2dB
33Hz= 139.6dB
25Hz= 136.8dB
20Hz= 136.1dB
