Ok, So after much thought and debate, i just cant see walling my truck with only 4 woofers, so i have a basic retangle box at 20x62x20 in mind and i really want to try a Kerf'd box for this build.
My questions:
How do i figure the port area when both ends Flare out?the port needs to be 18.5x8x10 to get my 37hz tuning, but if im figuring this the way i think its done, the acual port length that isnt kerfed would only be 3.25inches long
How do i measure for the kerfs to Get different radius'? I need to make a 90* within 3-4ins, is that way to tight of a bend for the MDF?
Sorry for so many questions, if this was sheet metal i d have no problems...hahahaha
Ill redraw the box to clean up all my "oops" lines and scan it in for you guys to see what im talking about. its subs forward/port up BTW.
Edited by Gotz1lung
93 Chevy Silverado
Crossfire,Dayton
Soon to have 6 Lvl4 15s
DC Audio Dealer and Team Member
where the fuck are you gonna fit a box that wide?
here, if you cant read what it says, just ask.
it says: my rule: 1/2 the width of the port.
port is 10" wide and the kerf is 5" wide.
Edited by BanginOnABudget
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
i do the same. I just did a box the port was 8 inches wide so i made my kerfs with a 4 inch radius. for port area. the area you look at is the area thats isnt kerfed
My Sierra is 62 3/8 from cab panel to cab panel with the seat brackets removed. Its damn near 80 threw the pocket to the sheetmetal..:)
So from your example its gonna add 10in to the total length and 10in to each side of the port as far as area???
Thanks for the sketch BTW!
Edited by Gotz1lung
93 Chevy Silverado
Crossfire,Dayton
here is what I read when I started designing this is off of ROE
a 90 degree flair involves 10 cuts with a standard 1/8" width blade.
http://i121.photobucket.com/albums/o239/hu...eighths3inh.jpg
moved fence on my saw 1/2 at a time, gives a 3.5" flair
http://i121.photobucket.com/albums/o239/hu...ndahalfinch.jpg
moved fence on my saw 3/4 at a time, gives a 4" flair
http://i121.photobucket.com/albums/o239/hu...uarter4inch.jpg
moved fence 1/2 inch at a time, made 20 cuts all together. 6" radius
http://i121.photobucket.com/albums/o239/hu...6inchradius.jpg
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
http://www.soundsolutionsaudio.com/forum/i...showtopic=23110
heres a link to a thread i made on *** about bending mdf
Nice tutorial... I would have never thought of doing the Mutiple strip at the correct width of each cut.
Nice close ups.. Thank you
It looks as if I might be able to pull this off.. Does drilling holes in the cuts help that much more for strength. Ill prolly use resin instead of glue to fill with. It makes sense, air out resin in, and each one of those holes adds to the bondable face area...
93 Chevy Silverado
Crossfire,Dayton
I just wanted a quick way so multiple strips, takin one out each time worked great. I think all that drilling holes does is help draw in the resin. I just made a box with a kerf port i tried to drill holes for the resin but it got to be a hassle. i had to hold the wood bent to drill the holes too. i also backed the kerf with a layer of fiberglass
heres a link to the build i just did
http://www.stevemeadedesigns.com/board/ind...mp;#entry629336
yeah that works well thumper I think does that
  • Who's Online   0 Members, 0 Anonymous, 1383 Guests (See full list)
