Amalan Posted March 6, 2007 Report Share Posted March 6, 2007 dunno if this is in the right section but im looking at this bottle of spray paint and it says "Several thin coats give better finish than one heavy coat. Recoat with in 4 hours or after 1 week to avoid lifting." i spray painted something yesterday and i want to put a couple more coats on it but what the hell is lifting? should i wait a week now? Link to comment Share on other sites More sharing options...
majorpayne Posted March 6, 2007 Report Share Posted March 6, 2007 I would think that lifting would be like the paint bubbling up or chipping off, ive always heard that reffered to as lifting Link to comment Share on other sites More sharing options...
Amalan Posted March 6, 2007 Author Report Share Posted March 6, 2007 huh well why is there such a huge time span why in 4 hours or after a whole week Link to comment Share on other sites More sharing options...
lovellsz Posted March 6, 2007 Report Share Posted March 6, 2007 yea lifting is when it ripples up or bubbles up, this usually happens when the surface isnt cleaned well, any slight bit of oil or grease will cause paint to lift, before we painted my car it was scuffed down with some 400 gritt, then i blew the dust off with the air hose, after the dust had cleared i tacked it and then went over the car with asotone, or prep solvent, paint thinner works too, then i tacked it again and then painted. Of course this was with a car and using a gravity gun etc, but its the same principal RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho" Link to comment Share on other sites More sharing options...
lovellsz Posted March 6, 2007 Report Share Posted March 6, 2007 i mean it wont hurt it to paint it later that day just make sure you give it time to dry and you should be strait RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho" Link to comment Share on other sites More sharing options...
BAGGEDBIRDS.com Posted March 6, 2007 Report Share Posted March 6, 2007 I read it as telling me if you can get the last coat down within 4 hours it will stick/bond to the paint you applied. After the 4 hour mark the paint will be too dry and it could need to be scuffed to stick and you will want to wait for it to dry totaly before scuffing it. I know that most quality automotive paints have a "window" of time where you can apply paint to paint without prep. after that "window" you have to scuff the finish. This time also allows some of the solvents to evaporate out I believe. 1st SMD "System of the Month" Feb. 2007 Zapco Studio 500 (2) Zapco Studio 300X Zapco Studio 204 (2) (2) FI 12ssd's w/ copper coils DLS Iridium Tweeters DLS UR2.5 MidRange FI. N.7 Midbass JL Audio TWK 88 Mechman 370A Elite Alternator Link to comment Share on other sites More sharing options...
Amalan Posted March 7, 2007 Author Report Share Posted March 7, 2007 I read it as telling me if you can get the last coat down within 4 hours it will stick/bond to the paint you applied. After the 4 hour mark the paint will be too dry and it could need to be scuffed to stick and you will want to wait for it to dry totaly before scuffing it.I know that most quality automotive paints have a "window" of time where you can apply paint to paint without prep. after that "window" you have to scuff the finish. This time also allows some of the solvents to evaporate out I believe. well its plastic but the paint has already lifted i guess in two tiny spots where dust landed on it while it was drying (ugh) the plastic im painting is slightly cracked too what can i use to put in the cracks then paint over it? theyre small crack so im thinking like glue or something might work? not sure im new to this Link to comment Share on other sites More sharing options...
BAGGEDBIRDS.com Posted March 7, 2007 Report Share Posted March 7, 2007 well lets see a pic. But most of the time you can Ca glue (super glue) the piece back together. What kind of paint are we talking about. A color change, restoring factory color, is there texture on the panel? before i put anything on plastic i use an adhesion promoter. I use Bulldog then primer and what ever i am putting on it. 1st SMD "System of the Month" Feb. 2007 Zapco Studio 500 (2) Zapco Studio 300X Zapco Studio 204 (2) (2) FI 12ssd's w/ copper coils DLS Iridium Tweeters DLS UR2.5 MidRange FI. N.7 Midbass JL Audio TWK 88 Mechman 370A Elite Alternator Link to comment Share on other sites More sharing options...
lovellsz Posted March 7, 2007 Report Share Posted March 7, 2007 did you clean it before you painted it? And make sure it was completly dry before you began painting? And for the small cracks sometimes that can be covered up if you use a primer. RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho" Link to comment Share on other sites More sharing options...
LSN2meBoom916 Posted March 13, 2007 Report Share Posted March 13, 2007 So far I concur w/ what they^^ said. Only other thing: Consider the ambiant temp. If it's cold or humid sometimes the dry/tack time or "window" will change. It's kinda like fiberglassing or gluing, the "nicer" the weather the easier it is and generally quicker to dry. If it's cold or really humid and you gotta get the drying time down, set up some heat lamps or halogen lights, that should help. Prepping it IS key tho, clean it really well and let it dry completely before you start in on it. sometimes, if you use a paint that "skins" pretty quickly, and spray some over a layer/coat thats not dry yet you end up preventing the undercoat from fully drying and it will saty wet enough to "slough off" or "lift". Thats just from my exp. I've experienced that kind of thing w/ spray paint, undercoat, and rhinoliner too. All seems to work/fail the same. COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly. Link to comment Share on other sites More sharing options...
