so i'm getting ready to do the big 3 , but my engine ground to frame is on the opp. side of the batt, does it really need to be on the same side as the batt ground to frame or is it alright to just run it on the other side along with the stock one?
Replace the stock one and then add another from batt to frame.
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
My engine ground to frame is also on the opposite side as the battery, you should be fine. Just clean the ground points down to bare metal so you're not grounding to paint.
97 Maxima SE
Bunch of shit going in, check out the build
  • Who's Online   0 Members, 0 Anonymous, 986 Guests (See full list)
