I recently got an in-dash screen. I wanted to know if anyone can help me out with bypassing the parking brake safety feature. I do't care about watching movies and driving but many of the other features are disabled unless the parking brake is engaged.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
What kind of unit? (brand, model) Some models with GPS you can't override. Some others you need to do a "on-off-on-off" sequence with the parking brake.
1996 Vw Jetta
Crunch 1500watt
1- Kicker 15" L7 @ 1ohm in a 4cu. ft. Ported Enclosure Tuned to 32Hz.
4- 6.5" Menace Door Speakers &
2- Menace super tweeters in the dash
139.11db @ 40hz (6/2010..old amp setup)
i believe that there should be a pink wire. possibly a diff. color depending on your deck..but its my understanding that all you ned to do is ground it so the deck thinks that the e-brak it allways engaged..or its the opposite way, that you dont ground it. but im pretty sure you do
The shop that installed my Clarion Touch Screen put in a toggle switch for me when they installed it under the dash, so just a quick flip and it lets me use all the features while the car isnt in park. They also told me if I ever get caught with it that it wasnt them that installed that toggle switch.
¿ǝɯɐƃ ǝɥʇ
I figured I either needed to ground it or hook it up to a hot wire. Just didn't know which one. Thanks
u ground it i have never seen one go to a hot wire. Also u might have to put a switch on it to do the sequence if just grounding it does not work.,
94 lincoln mark viii
h/u: kenwood kvt 614 Excelon
comps: alpine type x
amps: mtx 1501d mtx 4004
sub:2 DC lv4 12
wiring jl audio 0awg 8 awg sub
jl audio 4 awg for mid and highs amp
myspace.com/kylecm85
carstereolexington.com
What exactly do you mean by sequence?
my head unit (jesen uv8) you enter 054321 and a boot screen comes up you go to E-brake over ride and ta-da
Jensen Uv8 Head unit
1 12" Mtx Thunder Svc
2 12" Jl Audio W3D4 Dvc (both bridged)
1 Sony Xplode 1000 watt.
1994 Ext cab Dodge Dakota
My Daily ground pounder
On my Pioneer there is a wire labeled for the brake and I just hooked that up to a toggle switch and it works
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
What was the toggle switch running from?
  • Who's Online   0 Members, 0 Anonymous, 1639 Guests (See full list)
