i just have a shitty pioneer 760 watt amp for now. its like 158 watts rms x2 at 4 ohms
I myself am running a pionner shallow right now. I like the way it sounds, and get loud for a shallow mount. I have it in a 1 cube box tuned to 30 hz. shakes my truck up. The only thing is, is that it has a Fs of 55. It should be used as a mid bass, but it doesn't do bad on low notes. Here is a video of it in my old box. I dont know how to film stuff, sorry in advance
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350"> Edited by blue86f150
formerly known as Blue86f150
this sux camel dicks
those shallow pioneers are slimmed down, slightly weaker versions of thier 3000 watt spl subs, hella good buy, but i would say buy whatever you have room for, asfar as a box. plan ur box first, and see what you CAN do, so you have a better idea.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
im sure i could get close to 2 or 3 cubes from under my back seat.
well two of those pioneers would be a 2 ohm load if you put em on one set of wires, so you wouldnt need much power. i would say go for 2 of them.
If you can afford it, i would get one of these : http://www.sonicelectronix.com/item_15350_...io+13TW5-3.html
F-F-F-FUKK THAT
i never really heard a JL 13TW5 before the car toys store close 2 me has one on display in a custom box but its not hooked up as usual
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
  • Who's Online   0 Members, 0 Anonymous, 2129 Guests (See full list)
