bennett15 Posted June 1, 2009 Report Posted June 1, 2009 So today i wired my FI Q to .7 ohm thought it was wired to 1 ohm and hooked it up to my Bxi1608D and it instantly started to smoke and it still turns on but i get now output from it what so ever. I also re-wired it to 1 ohm and still got nothing. So i need an amp that will do a solid 1500 wrms at 1 ohm my budget is $400 shipped to Canada. 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
Kicker Guy Posted June 1, 2009 Report Posted June 1, 2009 So today i wired my FI Q to .7 ohmthought it was wired to 1 ohm and hooked it up to my Bxi1608D and it instantly started to smoke and it still turns on but i get now output from it what so ever. I also re-wired it to 1 ohm and still got nothing. So i need an amp that will do a solid 1500 wrms at 1 ohm my budget is $400 shipped to Canada. How did you rewire it .3 ohm different? Head Unit: Pioneer DEH-P6000UB Sub Amp:American Bass VFL 500.1 Subs: 4 Fi BL 18's Enclosure:21.5 Cubic foot flat wall tuned to 40 hz Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood. Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars Highs Amp: Kicker kx250.2, kx100.2 Wire: 4 Runs 1/0 gauge Knukonceptz
zfrerichs Posted June 1, 2009 Report Posted June 1, 2009 LOL I go ahead and say the .7 didn't blow the amp the load was over 1 after box rise Roseville, CA
bennett15 Posted June 1, 2009 Author Report Posted June 1, 2009 before i had it wired + to - then + to - then another + from one coils + term to the box then another - from the other coils - term to the box. 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
bennett15 Posted June 1, 2009 Author Report Posted June 1, 2009 LOL I go ahead and say the .7 didn't blow the amp the load was over 1 after box rise thats what i thought before i hooked it up i checked the wire leads with the dmm and it said .7 i was like okay with box rise it will be over 1 so i turn system on i could here the sub move a little bit then proceeded to turn deck up then amp made whole bunch of noises like fuses were blowing then it made the magical white smoke and there was a lot of it. Fuses never blew out and amp wasn't even warm but it still turns on but sub doesnt even move. 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
BanginOnABudget Posted June 1, 2009 Report Posted June 1, 2009 http://cardiscountstereos.com/catalog%20pa...ct+%23=BXI2010D ive used them before, not the fastest, but the most reliable ive used. tries to keep shipping as small as possible too. use the discount code 9998 for $10 off im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
RamenNoodles Posted June 1, 2009 Report Posted June 1, 2009 um no. That .7 is in reality run at 1 ohm with 1 dual 2 subwoofer. You have some other issues rather then your ohm load. Probably no electrical or a short somewhere. Diablo Audio Technologies Fi Car Audio Ascendant Audio
finkster Posted June 1, 2009 Report Posted June 1, 2009 yea my guess is you wired it wrong, based on how you're explaining it... DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
bennett15 Posted June 1, 2009 Author Report Posted June 1, 2009 i have big 3 done in 0/1 gauge and 2 batts wired in series voltage only drops to 13.8 and then amp never shut off i cut the engine when i seen the smoke. 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
