Maxx-link Help
just picked my Maxx-Link up last weekend. Im trying to get some insite on it though. Basically I was reading through the directions and it shows how to strap 2 amps to 1 sub and 4 amps to 2 subs. I dont wanna strap my amps though. im running 2 amps and 2 subs, but I wanna run 1 amp to each woofer. I bought this so I could basically use it as a line driver and to get the gains set easier. Anyone have any experience with these that I might be able to talk to about it
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
yea instead of spliting off the rcas left ch and right ch for 2 amps linked you will run the first set of outs to the first amp and the second set of outs to the next amp, follow the rest of the directions in the same manner
American Bass*DC Power
thats what i was figuring....thanks dude
Hit me up Jimmy ...ill talk you through it ...
i just may do that.....ima work on it tonight sometime so ill hit u up later when i get off work
www.4xspower.com
im running 2 sundown 3000s...so I would run the left and right channels of one amp to say the "-" channel of A and B on the MaxxLink and not use the + at all?
www.4xspower.com
Correct.
Im currently using my maxxlink the same as you.
If you use a POSITIVE and a NEGATIVE to one amp, the 2 will cancel each other out resulting in now sound output.
So whichever maybe easyiest to you.
Use a 2 channel rca and use channel A and B negative outputs into the first amps left and right rca input. then use channel C and D negative outputs into the second amps left and right inputs.
Or you can do pratically the same thing as above, but only use channel A negative output from the maxxlink and add a Y cable/splitter at the end to split the signal between the 2 inputs on the amp (as shown in the maxxlink manual). Then of coarse channel B output to the 2nd amp with another Y Cable.
Correct.
cool....thanks bro. that helped out alot. it'll keep me from going nuts later wondering why it wasnt working right lol
www.4xspower.com
  • Who's Online   1 Member, 0 Anonymous, 941 Guests (See full list)
