MileSwimmer4444 Posted June 3, 2009 Report Share Posted June 3, 2009 Ford made the 97-03 F150s with the black plastic trim around the back window and on the front bumper...is there any way to sand that or something so it can be painted? Quote 4 - 15 Sundown Z v.2 @ 35Hz 2 - AP3000D 2 - RF Power Punch 6.5 Comps 2 - RF Power Power 1 - Kinetic KHC2000 3 - Kinetic KHC2400 Iraggi 300A Knu Wiring Link to comment Share on other sites More sharing options...
kremsrx7 Posted June 8, 2009 Report Share Posted June 8, 2009 Ford made the 97-03 F150s with the black plastic trim around the back window and on the front bumper...is there any way to sand that or something so it can be painted? you can prep it like a normal panel but use plastic primer before you put normal primer on it, then it just like a normal metal panel, but if you sand thru to the plastic again, you need to put some plastic primer on it, otherwise the paint will flake off it, also if it needs to flex a little, you may need to add a flex additive to the pain and primer, any good paint shop can help you wit this. krem Quote Link to comment Share on other sites More sharing options...
B Slaps Posted June 8, 2009 Report Share Posted June 8, 2009 Ford made the 97-03 F150s with the black plastic trim around the back window and on the front bumper...is there any way to sand that or something so it can be painted?i think if you just scuff it up with scotch brite it should be ok. but yea you should use some plastic primer. Quote I Rock 4 Doors 4 More Whores! SMD SUPER SELLER my seller feedback http://www.stevemead...-mama-feedback/ more seller feedback http://www.stevemead...-slaps-yo-mama/ Link to comment Share on other sites More sharing options...
Airborne Posted June 10, 2009 Report Share Posted June 10, 2009 Use red scotchbright pad to scuff and adhesion promoter before primer. You can add flex agent if the pieces are flexible (not like rubber). Quote Link to comment Share on other sites More sharing options...
