draw a wiring diagram , take pictures of what you did and post em up! It will be easier for us to help you if we see what you have done.
Too Much Stuff to list .
on my car both wires are + until the dome light is triggered then one goes negative..... something to think about.
DC.jpgDC POWER
I opened each door individually, then pushed the switch in (you mean the little plastic button-looking things, right?) and it didn't have an effect. Could the switches themselves have gone bad? But all 4 at once...doesn't make sense to me.
No I believe it would only need 1 failed switch to cause your problem. Yes they can go bad. I've repaired them many of times on older chevy's, however usually the problem was that the switches wouldn't turn on. Depending on the switch design, I would believe that some cars could short at the switch and cause the lights to stay on.
That would definitely be what I check first, then I would try taking a step back at whatever splicing you did and see if the problem still exists.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
I will get more detailed diagrams and pics if not tomorrow then Saturday and post them. If anyone has any other ideas of things to check while I'm tearing stuff apart, post it up. Thanks in advance =)
Too many projects, too little time...
  • 3 weeks later...
