ok so im changing things up on the lumina.... im going from 4 10" alpine type s's to 4 12" type r's.... and ive got 2 different designs to choose from.... and im wondering which design would give me the best results... in a trunk...
this first one is the same type of design that i did with the 10's its subs up ports back...
for the type r's the first design is for 4 4" round ports
the second design is a slotvented enclosure, subs up vent up.... the vent is 28.5" x 2"
now in my saturn i always had better results with ports back but im wondering if the slotvent will kinda "outgun" the round ports back.....
let me know what you think...
Edited by Rogers
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
What are the choices theres only a pic of 1 box?
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
ok there we go.... im just wondering in general which alignment would be ideal over the other
3 Kinetik Hc2000's
Dual 200amp alts.
Whats the measurments of the first box? Correct me if Im wrong but the 2nd box is 8.75 cubes before displacement with only 57 sq in of port. That seems a little small???
no they should both be around 5 cubes net... wenn du or hower he spells it designed the second one
Edited by Rogers
3 Kinetik Hc2000's
Dual 200amp alts.
ugh idk what im talking about tonight lol.... anyways here is the plans for the first box
(4) 4" round ports x 18" long= .44cuft 35hz
+.28= .72cuft displacement....
5.9cuft gross internal volume.
33"wide x 15"tall x 27" (double baffle) =5.92
and here is the other half of the sketchup for the second...
3 Kinetik Hc2000's
Dual 200amp alts.
Ok I gotcha! wasn't sure how much displacement you had with subs, ports, etc. Can you not do a subs up port back design with a slot port? I like that alignment but I'm a fan of one big port.
