I have a hk4000D pushing on of my 18" BTL and iv got it wired to 1 ohm the amp does fine at lower volume but when i turn it up the amp shuts off does it do this because it isnt getting enough volts or wat???
~REFS~
-CA.com-Gianotti(2 18" FI BTL D1) Slowd N Throwd(Wiring),Ebrunn(PC monitor),Rab(HK4000D)
-SMD.com-Nismofreak(Radar),BigP(Phone Headset),anonymous(Xbox360 Headset)
If it is the MA Audio HK4000D, I had (6) of these amps at one point and had to bypass the protection circuit or it would cut off under stress rather easily.
What is your voltage at the time it cuts off ?
I've heard they're very voltage hungry. Maybe all the bypassed protection circuits are why you see so many of these amps blown up :P
10.x volts fo' life!
those amps the protection cuts it off at 1 ohm because they only rate it at 2 ohm stable you have to bypass the protection to keep it from cutting off at 1 ohm any lower on a weak electrical and get ready to toast some marshmellows.
TEAM GROUNDPOUNDERS INC.
156.5 OUT THE TRUNK OF A 95 CADDY
W/1 SUB & 2AMPs
score done on a termlab mic in the kick
on the dash sealed was 154
whats your electrical system looking like...sounds like a voltage issue
i had an amp do that to me before...such a stupid mistake...the last battery in the "chain" came disconnected from the rest and wasnt getting charged...it dropped down to 9 volts and the amp went into protect. make sure all your connections are tight and your electrical system is strong
NoFearX18 said:
trainman0978 said:
be very carful runing that amp at 1 ohm. we had one catch fire at 1 ohm.
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
These are not rated to perform @ 1ohm, you need to have it modded to work below 2ohms, and you need a strong, strong electrical system for it to perform well, even with a strong electrical not a guarantee that it won't go up in smoke. I would burb @ 1ohm but I wouldn't run it daily at 1ohm, even if it was modded. It's sort of a high risk, low reward running it @ 1ohm, what you gain in watts is not worth what you give up in reliability.
supercharged hummer h2
8 Sundown nightshade v'2 Scott Bowman built 4th order bandpass
2 precision power pcx 4125(mids & hi's)
2 Stetsom 14k2e's
alpine ina-w910
dual Mike Singer350 amp alt
8 kinetic 2400 batteries two shuriken bt 120
1 kinetic 2000 under the hood
link to build log:
My link
if I am wrong btl sit a good bit lower then 1 cold. like .65
*1) AudioQue 20k
my electrical is all stock n my alt is only 117amps...only thing i got goin for it is 0gauge....I was thinking of wiring my sub to a higher ohm load..i would b able to wire it to 4ohms wouldnt i???
the amp kicks off when it hits in the 9volt range on the screen
Edited by Tkitt21
~REFS~
bro you are going to smoke that amp! no doubt in my mind.
Just stop, run the amp at 4 ohms, and upgrade you electrical!
*1) AudioQue 20k
