ok i just installed dual alts and everything was running fine, but last night my rpms where droping to like 400 300 almost to the point where it was about to die anyway, i think the belt might be slipping would this cause i drop in rpms?
what else could i mean i haveing changed anything so i dont kow what it could be
I Just told you in the other thread that you probably need to clean your throttle body out. Mine does that EVERY time it gets dirty, probably once a year.
A slipping belt wont cause your idle to change. It might squeal a little but thats about it.
Follow my Tweet (Twitter)
I would guess the belt is too tight putting a strain on the engine. Were you pulling a lot of current when this was happening?
wrong bro, he has a spring tensioner - you can have a too loose but you really cant have a "too tight".
sorry steve i missed the throttle body post, makes sence cause last night was the farthest trip i made sence new alts when i had to take off the air intake hmmmmm sorry for this repost
What are your batteries sitting at voltage wise in the morning BEFORE you start it up. If they are low or you have a bad batt that will load down the alts and drop your idle. ;)
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
its coo.....clean out the TB and check back :)
Wait early 00 Tahoes still have TBI? Learn something new every day....
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
ok everytime i cleaned it before i just wiped it out, what would be best to clean it with? i want to do it right this time
ya bro i just usually wipe mine out too. You can put some brake cleaner or something on the rag to help it out a little...
when mine gets dirty, my idle is all over the place so im pretty sure thats what is doing it.
