What sub and how much power?
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
1 6" aero might even be the most efficient since it has less surface area of port to create friction... its 28.27sqin... and might act more like 40-55sqin
17.8 total length
see... just listen to us and do 1 6"
well if i use one 6'' i need to make sure i got room. how much is the cut out and the total width of the flare on the port? this is a single cab truck so things are limited on space. i got 8'' depth and 15'' height to work with. i can let the port come out the box some but to an extent, mayble like 6'' or 10'' max outside the box.
driver is a AQ15''HDC3 on a AQ3500d amp.
i have already ordered the 4'' port lol and just got to the house today so if i can use the 4'' and would sound good ill use them. just not sure if the 6'' will work if the lengh is to long
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
ok im going to go with the 4'' tube since ive already ordered it and i believe the 6'' will hit the passenger seat head rest or may just be to big in general. i can get away with the 4' flare.
Decaf along with me and Krannyman92 have come up with these measurements for the box. 3 4" port tubes at
26.5 total length for each tube. is this correct? i just want to double check before i order the other 2 ports
1 3500d AQ amp
