Alright guys been playin with designs to fit 18s in my truck... Im cutting my wheel wells out 3inches so I can slide my box right in... So my max measurements are 33L x 46W x 20H Doing subs up, port up... Figure sub displacement .25 each and Ima just do 1 45 for port and do a cross with 1" dowel for bracing baffle and sides... Also glass them a bit..
Need atleast 12cubes but if I get decent port area and low tuneing I have a little less and then if I keep my port area and just tune higher I got plenty of airspace... Donno what I should do...
Also power wise... They 2x lvl4 /w lvl5 coil 18s off a saz1500 each....
Edited by Got_Bass89
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
I was going for like 33hz.. I like the lows but if I can tune higher and still get the lows thats fine.. Not like C&S lows but you know what I mean..
Anyone else got thoughts working with that mount of space?
Passport Build Here
I'm no James- but this is 12.2cuft @32hz 5x 31.5" port 13sqin per cuft
LMK if you want a cut sheet
-Drew
uhoh_45 said:
Looking to do port off back glass since its at an angle and shoots air forward...
Anyone else for any ideas? Anyone have experience tuned a bit higher?
Passport Build Here
12.2 @36hz 180sqin of port off the back
-Drew
**14.75 sqin of port per cuft and i pushed the height up .75
Edited by Noobtastic14
dam drew i might ask you to help me on my wall lay out good job man
new system in the works
(3) DC lvl 4xls 15's (one of three are here)
(2) DD z1 (done)
old kenwood four ch
4 runs of 2/0 (done)
? 200 amp alt may two ??
No- with a double baffle it should be fine.
if he is worried about panel strength during the build a touch of glass will ease any worries
-Drew
  • Who's Online   0 Members, 0 Anonymous, 1005 Guests (See full list)
