XS Power
how many d3100's are needed for a 10,000 watt system? also the truck is bagged with dual compressors and has a 200 amp alt.
'00 Honda Civic Si IASCA stock trunk/pickup 1 World Record 4/20 150.6/150.7dB
Team DC Team XS Power
Team ISB
Steve's Body Shop
http://www.dcsoundlab.com/
Id say at least 4 to 6 batteries. 4 would probolly be good enough, but 6 is just going to be that overkill that is always great to have.
This will allow you to beat longer, and still have reserve left over for the compressors.
is that really needed?? I mean two bats would have huge Ah rating and even bigger max amps... with 4 you could bang a lot longer, I'll give you that
Got carbon fiber dust cap???
it sounds like you want to play music, and with only a 200 amp alt it starts to drain the batteries, so i say 4 also
HHR
(2) 15 DC Soundlab Lvl4XL SPL's
(1) Soundstream XXX-15000D
(9) XS Power D1000's
XS Power - Soundstream
SS N/W 155.1 db and climbing
at least 4 of them. if your running a true 10,000w or even like 5000 or so, a 200amp alt wouldnt really keep the charge up since about 100amps will be used to keep the batts charged and the rest of the car running.
Im affraid to run a good underated 6000rms off 2 batteries with a 270amp Mechman alt, and all other wiring upgrades.
dont forget this guy has compressors to be running off the batteries too.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
  • Who's Online   1 Member, 0 Anonymous, 576 Guests (See full list)
