Aq 3500 Vs Sundown 3500
grizzleyadams69
if running 16v id say sundown... otherwise they are pretty close
you save 150 but might not get equivalent power on 12v... both ratings are at 14.4v too... so wattages are similar til u go above 16v
Sundown saz amplifiers are all rated at 12.8v and will do rated power or better there.
If money is not a big deal I would go with sundown, but if you're on a budget the aq amps are the best for the cash. I love my AQ1200 but I really wanna get my hands on a sundown amp just to try'em out.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
copied right of the website
Double Sided Through Hole Epoxy PCB
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
MSRP $1549 USD
i actually thought they were rated at 12.8 but then i checked on the sundown website
I don't care what the website says, they are rated and will do rated power or better at 12.8v. I own and have tested every single Sundown saz amplifier there is including the prototypes that aren't out yet.
  • Who's Online   0 Members, 0 Anonymous, 689 Guests (See full list)
