ben29555 Posted June 14, 2009 Report Posted June 14, 2009 i got a 97 sonoma i hooked up the alpine deck in their it worked at first then later i tried it and i woulden't work so i took it out and tried to rewire it. still woldn't work so i took it out then replace the fuse and tired times after. still never worked. check the ignition power wires and ground they were both fine so if figured the deck was broke so today i went and bought a cheap quantum audio one hooked it up and it wont work ether. no idea why the stuff won't work please help My Build Log loud bass songs
devsmazduh Posted June 14, 2009 Report Posted June 14, 2009 may be a dumb question but, do you have good power going to your h.u? double check your ground. use a test light or dmm. like i said, uve probly already done so, just tryin to help a brudda out ill cut out yo eyelids and give ya nothin but sleeping pills...
ben29555 Posted June 14, 2009 Author Report Posted June 14, 2009 yea the power going to it is good tested it again today and hooked up the stock radio and it still works My Build Log loud bass songs
ben29555 Posted June 14, 2009 Author Report Posted June 14, 2009 anyone have an idea of whats wrong My Build Log loud bass songs
Stephen Posted June 14, 2009 Report Posted June 14, 2009 maybe your wiring it wrong? you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
Jville140db Posted June 16, 2009 Report Posted June 16, 2009 just a silly question when you are checking your power are you using a test light or dmm because if your using a test light it may light up but you still may not have proper voltage is the factory harness still intact and does the radio not turn on at all or is it just no sound sometimes people confuse the two sounds like a blown fuse remember the factory fuse probably isn't rated as high as the new radio needs, check all your fuses not just the one labeled radio hope this helps. Car is 2010 Scion Tc Currently in car Deck- Sony XAV-60 in-dash mobile video system Speakers- Rockford Punch 6.5in comps in the front and coax in the rear Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service Wiring- all rockford nuff said Enclosure- Dual 12in custom box by SRQ Battery- Optima Yellow top with big 3 done Sound Damping- All Dynamat products 1-2 layers throughout with liner on top Link to my build log- http://down4sound.co...=newpost&t=5275 Link to my youtube- http://www.youtube.c...ser/Jville140db MECP Advanced CEA # 110531 BassBox 6 Pro for Box Building/Re audio box calculator If you can hear the passenger it aint loud enough!!!!!!! QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
