Well i already own a hifonics bxi2006D amp.. and am currently wondering how much real power it puts out?.. My truck has stock electricals and 5g wire. I am wondering around how much real power its putting out since i know they are over-rated but was the best i could afford at the time.
With stock electrical and 5ga wire.. Im amazed you havnt smoked it...
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
have the correct electrical, and ull be able to be jus a lil under the rated rms
if its a Brutus it does 2000 rms, a Crunch Gp 3000 does rated rms and than sum ect
all bout electrical
Fear The Quack!
Shot at 2007-08-19
x2
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
what exactly do you mean by this?.. well i have 5g from the battery to the amp then 5g as ground aswell?
thats a small wire to pull that many amps through. upgrade your wires to 0 guage and i bet you'll notice a difference.
you'll probably even have alot of voltage drop with the upgraded wire because the amp won't be limited by the wire.
You should run 1/0 wire and upgrade electricel... thats what they mean
yea im going to do 1/0 wire this friday when i get paid.. and by upgrade electrical what exactly is that? meaning upgrading alt?.. sorry about these idiotic questions just got into bass recently and am ilinformed
He just means that you are overloading the wire and that you could have SERIOUS electrical issues on your hand within the near future. Anytime you go over 1000RMS(some cars I would do it over 500 anyway) you are suppose to upgrade your stock electrical wire to 0 gauge. Most of us in increments of 1000 double the runs of wire to keep the load down. So you are actually pushing your factory accessories off of the wire and then the system too which is a major problem when it comes to keeping your voltage high enough to run everything properly. Your amp isn't going to do it's rated power and you could risk frying it because your voltage will dip too low. Whoever installed it for you could have mentioned it or if you did you should have done a bit more research on the matter.
It's not going to do anything close to 2000watt RMS at 1ohm though that's out of the question. Only way to tell would be to clamp it
1993 Chevrolet SWB Pickup
Viper 791XV
Primer Stage
5/8 Static Drop
Kinetik HC1800
Big 3 Knu Flex 0
Team Tex Flex
when you double the runs of wires that means you have like 2 or 3 1/0 gauge going to the battery?
  • Who's Online   0 Members, 0 Anonymous, 13098 Guests (See full list)
